Message |
From the website, it looks like they are upgrading the TD06-18G's compressor and turbine wheels. Not an upgrade from TD05 to TD06. To answer your question, TD06 lag is not terrible with a proper setup. Set your boost controller to open the wastegates closer to full boost. I get 7psi in the first gear without launch control (2 step rev limiter). And you have launch control, you can leave the line with boost. With my launch control from the Haltech ecu, I can get 14psi off the launch. I desperately need traction control to regulate the wheel spin. Otherwise, it just melts tires. So no, the lag is not bad at all with the proper setup.
www.ztechz.net ICQ # 14337317
